Advent Lighthouse
Hochgeladen am 17.12.2010, 18:09 von ft_idaho.  60 / 71
Schlagworte: Advent, Lighthouse.
This is a (admitedly sad) lighthouse for an advent calendar.
werner (20.12.2010, 18:07:00)
Hi Do you don´t think that this is a bit too simple ?! / Findest du nicht dass das ein bisschen zu einfach ist ?! WERNER
ft_idaho (22.12.2010, 00:26:59)
Perhaps. On one hand I like having 24 tiny models with less than 20 components. On the other, you can create fairly complicated scenes or devices. In this case, just seeing what I can do under the tight deadline. Thanks! -r
